dougrainer
Oct 28, 2016Nomad
If you figure out it is the check valve, replace with a BRASS check valve. They have larger orifices than the Plastic check valves and will allow more volume of water and minimize the water noises. The brass has the same size 1/2 inch threads. Doug
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
