rburke wrote:
Ok thanks all the issue was definitely the bypass! I found the valve and turned it off and now have nice hot water while running in propane. The water is not getting hot running on electric, its warm but not hot so there is some failure in the electrical component of the water heater. Have not had time to diagnose yet but any pointers are much appreciated.
That's great, and thanks for reporting back. If it works fine on LP but not so well on electric, could be simply that the anode rod is bad and needs replacing.
