Mfan wrote:
Flush, flush, flush. Then sanitize with bleach, and repeat
X2
NEVER LET WATER SIT IN A SUBURBAN WATER HEATER!!!
That can't be stressed strongly enough. This isn't optional, it's a must! Not all water will cause the anode to breakdown and stink but most campground water is well water and chances are very high it will cause problems.
You must pull the anode rod after each use and drain the tank. Failure to do so will sooner or later result in a rotten egg smell that's hard to get rid of. Flush it over and over, put a little bleach in it and fill it with water then let it sit overnight before draining and install a new anode.
Watch this video by Suburban Water Heater and become an expert in eliminating odors and maintaining your Suburban water heater:
RV Water Heater Odor Elimination - Suburban Water Heater Series 1 - Video 5NEVER PUT ANY RV ANTIFREEZE IN YOUR HOT WATER TANK!!!
If you don't have a winterizing bypass on your hot water, get one or have one installed! It'll save you more in time and trouble than it costs! Then before you winterize, drain your water heater and switch the valves. You'll use a lot less antifreeze and make it much easier to de-winterize in the spring. Me?, I blow my lines out instead of using the antifreeze. Just make sure you blow them out thoroughly and you'll be okay. Just put a cup of antifreeze down each "P" trap and quart down the toilet.
