mikestock
Feb 04, 2014Explorer
Probably need to replace the 1500 watt element. Lowes or HD sells them, along with the little wrench to remove and replace them. If you have a continuity tester you can easily check the element without removing it. Best to empty the tank first.
I burned one by accidentally turning on the electrical element while the tank was empty. Only takes a minute to destroy one like this.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
