Old-Biscuit
Jul 19, 2015Explorer III
rreynold51 wrote:
Its a Suburban SW4D RV Water Heater if it matters...
Cover on left with 'reset' is where the 12V DC set of t-stats are located. High temp t-stat will trip if water temp exceeds 180*F and can be manually 'reset' after water cools to 110*F
Need to remove burner tube and run a brush thru it....blowing air thru usually doesn't clean enough to be effective.
Run a wire thru combustion/exhaust chamber..tie a rag to end of wire and pull it back thru to clean out spider webs/debris
Then reinstall and check position of spark electrode......S/B directly engulfed by main flame
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 08, 2026
