In outside compartment is a rubber cover above the gas valve with 'PUSH TO RESET'
Under those buttons are resets for the Hi Temp T-stats....if tripped no Power for operation
The Left one is for the 120V AC and the electric operation
The Right one is for the 12V DC and the propane operation'
Push them both....if tripped you will feel them go in and 'reset'
Then while out there have SOMEONE ELSE turn propane switch ON while you watch/listen for:
Spark electrode firing....you should be able to SEE the spark and HEAR the click click click of the spark electrode
While the click/sparking is going on the gas valve opens for 6-8 Seconds (UNLESS a main flame lights off and engulfs electrode proving it has lit). If it doesn't light off/prove circuit board closes gas valve.
It can attempt this light off sequence 3X then it should 'lock out' stop trying turn RED Fault light on at switch panel
So try above and then post back what does happen and what doesn't happen
