Pattajames
May 21, 2018Explorer
Chris Bryant wrote:
Have you actually measured the water temp? I would before spending on a thermostat, as that version is pretty reliable.
If the whole thing is cold, it can take a long time to heat. It could be the TP valve is bad.
I just replaced the TP valve recently because the last one went out. Now when you light it, the heater stays heating (full flame) and never shuts off. Then the TP opens to relieve pressure and the water temp is EXTREMELY hot.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
