cracker465's avatar
cracker465
Hot water
have a mixmaster shower head and cant get any hot water. Can get in the bath sink but not the shower. I can get some in the kitchen sink. Any ideas? Thanks
  • cracker465 wrote:
    yes but kitchen on pulses very luke warm
    I'm stumped. When you do figure it be sure to let us know so we all can learn.
    Only remote idea I have is a winterizing check valve at the back of the water heater.
  • If you disconnect HOT line at fitting for Kitchen Faucet......put it in a bucket and turn on Water Supply bet you get HOT water.
    If so......faucet is junk
    Same for shower
  • Is it possible the hot and cold are switched at the shower? Grasping for straws here. No idea about the kitchen sink.
  • No dont think But got some info from lance saying maybe installed wrong at the shower of and on
  • Is your hot water bypass not fully in the un-bypassed setup? You could get varying temperatures of hot water with the bypass not properly set based on the pressure drops etc. between the heater and the faucet.
    If it's a water heater with a mixer valve on the output side, it may be worthwhile to check that the mixer valve is functioning properly, as well.
    Is this a new RV? We generally assume a system was known to work correctly previously. If it is new and never worked correctly it could be a lot of things.
    BTW, when asking any questions it is handy for us to know what you have. Either a signature or the information in your profile would help.
  • Brand 2016 Lance tc. Some info came from the loa. Saying the factory installed the faucet shower mixer wrong. And showed a fix. But that still wont take care of the gally sink. Have a service call next week.But will not take it back to the dealer i got it from
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
