cracker465's avatar
cracker465
Hot water
have a mixmaster shower head and cant get any hot water. Can get in the bath sink but not the shower. I can get some in the kitchen sink. Any ideas? Thanks
  • Im getting hot water in bath sink. But cold in shower. One in kitchen will let a little luke warm then to cold
  • Are you getting water from the hot valve that isn't hot? Or are you getting no water at all from the hot valve?
  • All outside shower shut offs are tight. Maybe the shower valve its self.
  • Had the same problem once - the outside shower faucets weren't off tight.
    Bill
  • Old-Biscuit wrote:
    Remove shower-hose from faucet connection and turn hot side on......any hot water flow?
    Remove aerator from end of kitchen faucet..........any hot water flow?
    Is hot water flow at bathroom sink faucet normal/strong flow?
    Is water HOT from bathroom sink?
    plenty hot bath sink. Will follow up on youe sugestions
  • Do you have an outside shower? If so, check to make sure the knobs are turned off, not just the shower head.
  • Remove shower-hose from faucet connection and turn hot side on......any hot water flow?
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 15, 2026
