dougrainer
May 07, 2021Nomad
BFL13 wrote:
If that inverter is this one, it says:
"Back-up Capability with exceptionally fast transfer time just like the UPS - If incoming shore power is interrupted by external events like brownouts, the Freedom X automatically becomes an independent power source that supplies utility grade AC power to your loads when installed with
DC battery"
IMO you don't want it to automatically come on whenever you disconnect shore power. That means with this model, you do need to be able to disconnect the DC input.
http://www.xantrex.com/documents/Power-Inverters/DS20170805_Freedom%20X%201200.pdf
ALL RV Inverter/Charger's IF TURNED ON, will automatically transfer to Inv connected loads if there is a Shore/Genset loss of power. If you do NOT want this to happen just turn the Inverter switch OFF. Doug
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
