Nutinelse2do's avatar
Nutinelse2do
House Batteries not being charged by engine.
Greetings all,
Been RV'ing for 30 years and we just bought a 2019 Minnie Winnie 22r on a Ford E350 chassis.
My house batteries are not getting a charge when engine running.
Batteries charge with Genny, and shore power.
I have read on all the different types of setup BIMs etc but none seem to fit what I have.
In the picture link below I have 14.4 V on the left side of the boost solenoid
Is it possible they made this RV with no charging to the house batteries from the engine?
What am I missing?
Thanks for you time and input
NutinElse2do
  • I suspect (and after re-reading I think you also mentioned) that the cylindrical item in the lower left is your solenoid for charging your house batteries while driving. Those do go bad pretty regularly (I've changed a few). Good news is they are inexpensive and that looks like a very easy location to swap it out for a new one.
    -Chris
  • Can you crawl underneath and trace any red battery cable running back towards the chassis?
    With everything off (no generator or shore power), measure the voltage on your chassis. Then measure your voltage on your house batteries. They (in your case) should be different. Then measure the voltage on some of those wires to the left of your house batteries. and see which ones match your house battery voltage and which match your chassis voltage. This will tell you if you have a chassis fed battery cable back in your house battery location (...a clue at least).
    You can also do these measurements/tests with the engine on. Your chassis battery will likely be somewhere between 13.5-14.3v. Then you can probe those battery cable wires near your house batteries and see if you find a matching voltage. At least this way, you will know if you have your chassis 12v cable in the area near your coach batteries. Then you can probably identify the solenoid that is supposed to charge your house batteries while driving.
    Good luck!
    Chris
