wolfe10
Sep 17, 2013Explorer
Two issues:
As you said, one large lug is connected to the chassis battery and reads correct chassis battery voltage (14 with engine running).
Problem #1 is that the other large lug which connects to the house battery should read that battery's voltage-- probably in the 12.5 VDC range, even with engine off.
Problem #2 is 7 VDC to the signal wire. You can use a small gauge wire (it will carry less than one amp) from chassis battery large lug to signal terminal (remove the signal wire first, so you don't back-feed that circuit). Now the two large lugs should read the same voltage, as they are joined through the solenoid.
Most Ford solenoids are intermittent duty-- you will need a CONSTANT DUTY SOLENOID of sufficient rating (amps).
