MEXICOWANDERER
Sep 17, 2013Explorer
luckydog3550 wrote:
Will any 3 post solenoid work?
NO!
There are INTERMITTENT DUTY solenoids
Then there are CONTINUOUS DUTY solenoids
Many cannot be told apart by looking at them. An intermittent duty solenoid that is incorrectly used for "continuous" duty WILL BURN OUT in short order.
It gets worse: About eight out of ten of those metal can "continuous duty" solenoids I autopsy turn out to be GARBAGE. Insufficient copper contact area, magnet coil windings that FAIL to have enough turns with big enough copper to have great magnetism (contact strength)*. A one ply tire with a ten ton load. How does one "pick out" the good ones from the garbage when they all look the same? After paying TWENTY FIVE DOLLARS for a supposed "top-of-the-line" brand solenoid, having it fail, taking it apart and finding it to be the same level of garbage as the ten dollar solenoids I am convinced only an ESSEX TOWER TYPE SOLENOID is with the bother.
*You can wind a magnet with FEWER turns of SMALLER gauge wire and end up with EXACTLY the same ohms resistance and two-thirds the magnetic pull. How ya gonna tell? Huh?
I have given up playing guessing games with solenoids used for battery splitting. Even the Cole Hersey brand now is garbage. A good ESSEX tower type solenoid is ten times the product.
When you run a WIRE to a switch, all kinds of things happen. You forget to throw the switch, the wire breaks, the terminals break, the switch itself goes bad. How many dozens of feet long is that EXPOSED switch control wire? This type of technology rates right up there with a tube-type adding machine.
A SELF-CONTAINED smart solenoid is the way to go. Remember something that may save your life and not being forced to remember throwing the switch. Use that memory slot for the better half's birthday or your anniversary.
A "smart" bi-directional" smart switch is the way to go. When ANYTHING charges ALL BATTERIES CHARGE, automatically. And only short wires are needed. Even a 15-year old can install one. They are SIMPLER to install than a regular GARBAGE solenoid.
I like the 200-amp model as they will go many years and NOT BURN OUT. I am a cheapskate but I am not stupidly cheap. One of these smart solenoids is the best money I've ever spent.
