luckydog3550's avatar
luckydog3550
House batteries not charging when coach running
I have a 97 Allegro Bus. The converter outlet has 120V when the generator is running and when I am plugged into shore, but nothing when the coach is running. Problem started when (i believe) coach batteries went bad couple weeks ago. The circuit breaker that the converter powers started tripping and resetting intermittently while running the generator. When driving home about half way they stopped charging completely. I put new batteries in and am where I am. Converter outlet gets 120V when generator is running and connected to shore power, nothing when the coach is running. Thanks for the help!
  • hmmm.....the chassis batteries ARE being charged when the coach is running, but not the house batteries. If the alternator is supposed to charge both, why would it charge one and not the other? Is there a fuse somewhere I'm not finding?
  • THE ALTERNATOR
    ON THE ENGINE
    Every rig has some sort of a device that SPLITS the power generated by the alternator. One side goes to the engine START battery, the other side goes to the HOUSE POWER batteries. How and why this SPLIT is accomplished, can vary with the type of coach and the brand of splitter used. You need to determine exactly what kind of a SPLITTER your coach has. Other forums members can help you discover what device your coach uses. There is also PROTECTION in the circuit to protects against SHORTS. These devices can FAIL, and so can the splitter. So the answer is to IDENTIFY and to TROUBLE SHOOT. In that order. The splitter including its controls, and then the protection circuit, the fuse or breaker.
  • luckydog3550,
    The alternator of the coach should charge the house batteries when running.
    John
  • Thanks for replying. So then what charges the house batteries when the coach is running?
  • Quote:
    If you talking the outlet that the converter plugs into, that sounds normal to me.
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
