doughere
Apr 01, 2015Explorer
If you go to Interstates website, you can see the AH capacity depends on the draw.
At 5 Amp draw it is rated 16.4 hours = 82 AH capacity
At 25 Amp draw it is rated 2.3 hours = 57.5 AH capacity
Amp Hour ratings used to usually be the 20 hour rating. BUT now you need to do a lot of reading to see what you are getting, lots of companies are advertising readings on different draws.
I have a pair of no-name 6V GC batteries, rated 300 AH, nowhere can I find at what hour rate that is (I suspect its the 100 hour rating). In real life, I'm sure they are really about 220 AH at the 20 rating.
Doug
Doug
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
