DAS26miles
Apr 01, 2015Explorer II
Update.
I recharged the batteries with the onboard Inteli converter charger last night. It recharged 51.2 amps as of early this morning and had gone to normal mode only charging at .5 amps. I brought out my 100 watt solar panels and turned off the house converter and connection to the batteries.
Let the solar panels continue charging for another 2 hours at .5 amps 14.5 volts.
Then I switched on the equalizer for 2 hours at 15.3 volts at 1.5 amps.
Now I am back to the solar panels normal mode of 13.8 volts but only .2 amps.
The Xantrex battery monitor says I am still down 5 amps from the 60 I was originally.
Why, is the charging systems taking longer than I would expect to fully recharge the batteries?
Next time I am getting the Trojan 100 ah group 24.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
