DAS26miles
Apr 03, 2015Explorer II
bought a new hydrometer. Thought it was giving incorrect readings. Batteries spent the last few days on the RV charging system and getting fully charged reading with volts. I even used the solar panels to give it more charge at 14.6 volts for 3 hours.
New hydrometer shows sg of 12.45 on both batteries and all cells are within .05 + or -.
The volts show 13.23 and 13.25. I attached one battery to my Vector charger on desulfation mode for 24 hours.
The other is attached to the solar panels at 14.67 volts and .2 amps for 180 minutes. I want to see iff the sg goes up any. 12.45 is .30 less than TOPPED OFF, right?
Update equalizing now 15.4 at .7amps should be running 120 minutes.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
