DAS26miles
Apr 04, 2015Explorer II
I tried using my extra 30 watt Renogy solar panel, not the 100 watt. I would have to disassemble the cables to the controller and splice cables with alligator clips on it.
For now, I am using NinerBikes DieHard 12v 6amp charger from the 70's. Max output is 16volts.
Tomorrow, I will try another round of equalizing using NineBikes and my 30 watt panel. I haven't seen any improvement with the SG on either so far. Perhaps I should let it go a full 2 hours each instead of until the volts stop climbing and actually fall. They lasted 30 minutes on one and 1 hour on the other before the volts began falling.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
