DAS26miles
Apr 07, 2015Explorer II
Pianotuna wrote:
Does the solar controller have an equalize setting?
Yes it does, 120 minutes at 15.2v. I have to set the date to the 28th of the month.
NinerBikes wrote:
Do you have a generator on board your RV? Go buy a MegaWatt 30 amp power supply unit online from up in AguaDulce, before you go camping. Set it at 15.0V before you go. Run your generator for 2 hours every morning at 15.0V... your batteries might do a little bit better, but you'll go through the same******again that you are going through now when you get home, from those PIA batteries.
Yes, an Onan 4000 micro quiet,Thanks, I need a routine to follow each morning. Will look into the charger. Thanks again.
Is this what I want?
S-350-12
30 amps 33 amp peak
13.8 VDC
Actual voltage adjustment on this unit is 9.5 to 15.5 VDC
Input 120/240 VAC
$50.00
or this from HRO
Variable power supply 0-24v
and this
Variable volts to 16
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
