NinerBikes
Apr 07, 2015Explorer
DAS26miles wrote:
Yes, an Onan 4000 micro quiet,Thanks, I need a routine to follow each morning. Will look into the charger. Thanks again.
Is this what I want?
S-350-12
30 amps 33 amp peak
13.8 VDC
Actual voltage adjustment on this unit is 9.5 to 15.5 VDC
Input 120/240 VAC
$50.00
Yes.
What voltage do you think you should set it at for bulk charging your current Interstate batteries?
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
