pianotuna
Apr 17, 2015Nomad III
Hi,
Another option for alternator charging is to add a second charging path. I chose to use an automatic reset circuit breaker rather than a fuse. I have seen 70 amps when I load up my house battery bank with the inverter.
I have manual control over the continuous duty solenoids, so I can deliberately limit or even turn off charging if I feel the alternator is working too hard.
Mex has suggested to others that an external alternator diode is a great way to get more energy from an alternator without burning it out.
I do push my charging system hard. My cut off is when the chassis is at 12.9 volts. When it reaches that number, I reduce the load on the alternator.
The two ways that make (financial) sense to 100% charge the house bank are shore power, and solar.
It would be wise to check the specific gravity of the electrolyte. I suspect you may not be happy with the numbers.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
