bigfootford
Apr 17, 2015Nomad III
DAS26miles wrote:
Bigfootford, the fridge is 2 way 12v/propane and 110v. My draw is .6amps normally with no lights, pump, fans or furnace going. It makes a difference with the solar, I guess it could with the alternator also.
Looks like 2awg wire going to solenoid and to batteries. 2/0awg cables xing across batteries.
Good. I have fought that voltage drop from the alt to house batteries as many others have.
The given advice is great so you should be able to get the drop down enough to aid your charge with the alt. I have a switch to control a solenoid and only use it in bad weather and night travel. My solar does most road travel charging otherwise. I rarely use Alt charging now.
Jim
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
