BFL13
Sep 02, 2015Explorer II
2oldman wrote:
You will need 4 batteries of at least 400ah total to comfortably fire up a microwave. And if your inverter is MSW, it will have to run twice as long as if you had a PSW.
No you can use the MW if the two batts are above 75% (see my post above) Good point about the inverter. If it is MSW it will draw way fewer amps to run the MW than a PSW inverter would to run the same MW, so it is easier on the batteries.
The extra time is less important for the AH usage. I don't find it takes twice as long.
Say your potato takes 8 minutes with PSW at 150a but 10 minutes at 100a (what I see in real life comparison)
150 x 8/60 = 20 AH, while 100 x 10/60 = 16.7 AH
So actually, as long as the MSW inverter and the MW get along (never mind the groaning turn table as long as it runs at all ) you do better with the MSW for MW work. Of course the MSW inverter has to be one of the heavy duty types rated to run motors etc.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
