Golden_HVAC
Sep 03, 2015Explorer
The Trojan golf cart battery is rated at 75 amp draw. That is a lot of power to put on a battery for a long time, such as cooking for 8 minutes. Even most drives that I do in the golf carts at my work involve picking up speed to 13 MPH, and then running part throttle, until there might be a hill. Uphill can draw max amps for a few seconds (20 seconds and you are at the top of the hill where I work), but downhill can actually charge the battery. Most drives are less than 1/2 mile, or about 2 minutes. (at 15 MPH you would drive it would take 4 minutes to drive 1 mile).
SO the Trojan T-105 that we use will last about 105 minutes at 75 amps draw before reaching 5.0 volts.
I would recommend a set of T-125 batteries, same size as the T-105, but a little more lead, and thus can hold about 20% more power. I have 4 T-105's. I used my microwave on my Trace M1512 inverter/charger, and it no longer cooks nearly as quickly, so it had to be replaced. Now I just run the generator while microwaving, or bake it in the propane oven.
I also have a 415 watt solar system to recharge the batteries. This keeps them nearly full all day long. It will help a lot when cooking at night. But like I said, I would rather bake it or cook on the propane stove.
I hate listening to my generator!
Good luck,
Fred.
Good luck,
Fred.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
