liketoride2 wrote:
Dakota98 Wrote: "Yes, the 9200 & charge wizard will mate well with the AGM type batteries & do a good job, but will not suffice for lead acid without a different maintenance program in place."
What maintenance program would be appropriate for a new TT with two Trojan T-105 batteries that will be used off the grid a good percentage of the time? I have no info on the stock system except it states on the owners manual:
"If the battery is below full charge, the converter charger will begin operation at a rate that reflects the level of discharge. When the battery is again fully charged, the converter charger drops its charging level back to a maintenance level to keep the battery fully charged."
We do not have solar or wind power. Thanks.
The converter charging system typically gets the lead acid batteries to approx. 90% only. If you are relying on your coach monitor system as the gauge to determine full charge, it's not really that accurate. A hydrometer, volt meter, or volt/amp meter is much more reliable, depending upon your specific needs. Here's what Trojan recommends for a maintenance schedule.
PS:
BFL13 wrote:
Also wonder if the PD 14.4 gets a good reputation more in warmer climates where that voltage is closer to say 14.6 temp compensated.
Point well taken, ambient temperature is a definite factor concerning battery charging & performance.
Trojan battery Maintenance
