DFord wrote:
The BatteryMinder I referenced IS TEMPERATURE COMPENSATED AND MEANT TO BE LEFT ON ALL THE TIME DURING PERIODS OF NON-USE.
AND!  It's on sale right for only $25 now at Northern Tools!
Features + Benefits
- Full-time battery monitoring automatically tests battery continually, supplying only the current needed to maintain battery at full charge
- 8-stage unit charges and maintains from 1 to 4 batteries at a time (12V batteries parallel-connected or two 6V batteries series-connected. NOTE: Never connect 2 or more batteries together in parallel before fully charging each and checking their condition. Failure to fully charge each battery and check their condition can result in a serious safety hazard)
- Does not overcharge, regardless of time connected
- High-frequency pulses safely remove sulfate from battery's plates that prevent the batteries from holding a full charge
- No need to add water to maintenance-type batteries during long, non-use storage
- Stops boil-out and ends water loss
- Smart chip technology ensures safe, long-term performance
- Automatic reset prevents damage to charger when unit is connected to faulty battery
- 10ft. output cord
- Blinks when charged
- Made to ISO 9002 Quality Certified Standards
- Comes complete with Quick connect/disconnect battery clips (Note: BatteryMINDer Plus will not cause battery drain if connected to the battery without connection to AC power 1mA max.)
- Not for use with aircraft batteries
- This model features Temperature Compensation which decreases voltage in hot weather (battery does not overcharge) and increases voltage in cold weather (battery will stay fully charged)
- This model will not work on a battery less than 6.0 Volts
I'm looking at the Battery Tender Jr. to keep my 2 twelve volt lead acid topped off.  They set parallel.  Can u comment on that particular one?
