MEXICOWANDERER
Dec 28, 2015Explorer
One hydrogen 2 oxygen atoms for water.
Perfect combustion occurs after combing two hydrogen atoms with one oxygen atom.
The AGE of the battery under discussion skews the relevancy of amount of overcharge present. A badly poisoned battery will bubble vigorously at 13.8 volts, or even fewer volts.
Converters SHOULD be selected via battery manufacturer's maintenance data, not by a converter salesman over the telephone. Absorbsion and float voltages are important.
Houston can get hot. For that reason, flow-through compartment ventilation should be made available for any type of battery.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
