campingwiththor's avatar
Jun 21, 2016
House battery "repair"?
Bought a new deep cycle battery at Walmart last April 2015. (29dc 845mca) Maxx
Installed & all was good. I left it in the camper all winter+ ( 7 months ) with shore power disconnected. The camper was outside all winter.
So- the battery is dead. I checked the water levels & it has water.
Is there a way to save this battery or because it was outside unplugged all winter it's a lost cause?
Tks,
CWT
  • Almot's avatar
    Almot
    Explorer III
    Noise.
    Disconnect them from loads - yes. And leave them floating on solar or whatever you have.
    Otherwise, - OP saw what could happen.
    New AGM - without floating charge - would lose about 10% after 4 months at 40-50F.
    Flooded, "near full" after 6 months?... If stored at the North Pole, maybe.
  • Replace it. Not covered under warranty. A battery that has been frozen can explode while charging.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Is there a way to save this battery? Likely no.. This is one of the problems with MARINE/deep cycle batteries, they are really starting batteries and when they die,,, they die.. Though sometimes you do get lucky.
    Try a slow charger, like 10 amps or less for 3 or 4 hours, then use your multi-stage converter to fill it up.
    But be aware. It may not last long, you may have lost capacity or it may have a shorteed cell (in which case it will nto charge)
    True Deep Cycle batteries can go down to half full safely, and stand a much better chance of recovery if you "OH S***!" them but... Even then in your case I'd not hold my breath.
  • if the OP had simply installed a battery disconnect switch, his battery would still be good.
    my two 12v deep cycle batteries sat for 5 months in storage.
    because i installed a $6 disconnect switch, they were still nearly fully charged at the end of the 5 months.
  • JUST FOR DRILL-----
    Charge battery on an old-fashioned wheel type battery charger. Charge on LOW setting until all 6 cells are not only bubbling, but roiling. Stop charging if you run your hand over any part of the battery and it feels hot.
    I believe Wall-Fart only allows a one year warranty and the pimply faced Auto Dept. "Associates" are told to be strict about warranties.
    Finding a garage that has an old-fashioned charger may be the hard part of this grand plan.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 18, 2025
