DrewE
Feb 20, 2018Explorer III
It may very well be entirely normal, as was mentioned, especially if the meter is taking its reading from somewhere not near the batteries and its a fairly high load; you have wire losses etc. to also add in.
I would suggest checking that the connections to the battery and ground are all good and clean and tight, and that the wire terminations on them are solid. A (comparatively) high resistance connection will readily cause these voltage drops. It is also possible for an internal connection in a battery to become poor and high-resistance; I had a battery, since replaced, that did this between the end cell pole and the stud where the wire attached. I don't gather that this is a particularly common failure.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 22, 2026
