Sam_Spade
Feb 20, 2018Explorer
tommymsw wrote:
When they are charging I get over 14v as expected.
The solar panel is only a 10 watt.
14 V is the CHARGING voltage, not the battery voltage.
And 10 watts at 12 volts is less than one amp; barely enough to maintain a full charge with no load. Not nearly enough to do any actual charging.
Trying to figure out if things are working right with the present setup is just a waste of time.
You NEED to get those new batteries fully charged SOON. Just sitting at half a charge for very long causes them to age more rapidly.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 22, 2026
