tommymsw
Feb 23, 2018Explorer
So one last thing.... If I replace the 10W with a 100W, do I need to change the solar inverter (or control system) that is in there already? Or just replace the old panel with the new one?
My instinct tells me that if the RV is set up for 12V solar already, that the wattage should not matter? As long as we stick with 12v, the current system should still work, (only faster I hope).
i.e. If you have one 100W panel, you should be able to add another or another without changing the charging system. The same way I can just add more outlets to the same line in my house as long as I do not exceed the maximum amperage.
Although maybe wattage matters in this case? Or maybe the amps matter?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
