Almot
Feb 24, 2018Explorer III
pianotuna wrote:
I'd jump up to between 400 and 600 watts, which, other than running an air conditioner may nearly eliminate generator use.
Yes. At least 300W solar for offgrid camping.
His camping situation wasn't made clear. "No boon docking", and then "to run the generator or plug in at a park and only rely on the solar to keep the batteries topped off from normal drain while it sat empty". If RV park has no electricity and you have to run a generator - this is the same as boon docking.
I would NOT buy bottom of the barrel off-brand controller, even for as little as 100W panel. In China deception is a perfected art. It stops working or won't work properly from the beginning and you end up with overcharged or discharged battery.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
