Bobbo
May 24, 2020Explorer III
This is what needed to be done, you can check to see if this is what you actually did.
1. Put Trik-L-Start to charge the CHASSIS battery from the HOUSE battery, not the other way around.
2. Plug in your MH so the converter/charger will charge the HOUSE battery. The HOUSE battery will then charge the CHASSIS battery through the Trik-L-Start.
If you put the Trik-L-Start on backward, so the CHASSIS battery is charging the HOUSE battery, and did NOT plug in the MH, the battery(ies) may have run down.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
