time2roll
May 25, 2020Nomad
gandk1011 wrote:
Ok, sorry i said that wrong. The house battery is good, trick l charge was charging the chassis good until recently. Now the MH is not send house battery voltage to the relay you attach the Trickle L Charge to so it can charge the chassis battery.
I believe you have an open connection between the house battery and the relay. Check your cable connections along the path from house battery to the relay. At some point you will find the drop off of voltage. Clean, tighten, replace, repair the situation you find. Trik-L-Start needs to see 13.5+ volts to be able to do anything.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
