I put a Trik-L-Start on my 2007 Class C (when I had one). Problem solved.
BFL13 wrote:
ISTR reading on here that there is a trick to the trickle start?
It only works when one set of batts is higher voltage or some such?
When the RV is plugged in to shore power, the converter/charger will be putting out AT LEAST 13.2v. Again, problem solved. (And, the Trik-L-Start only lets power flow one direction. Set to charge the chassis battery, it won't pull power FROM the chassis battery.)
BFL13 wrote:
Says here battery disconnect must be "on" (meaning "closed"? who knows???
That means the house battery must be charging from the converter/charger.
