D_MAX's avatar
D_MAX
How are holding tanks plumbed?
Need to pull a grey water tank and am wondering how the plumbing works on the top of the tank. Is it a slip fit with gasket or are the drain pipes glued to the tank/fittings. If glued I assume I have to cut the pipes in the trailer and then use an appropriate coupler to rejoin? Any advise or experience is appreciated. Cheers!
  • I upgraded my black tank, tank grommet and the idiots slathered it with white dicor mess as well. It may depend on tank material, the grommets are usual with PE tanks, the ABS tanks have spin on fittings if I remember correctly.
    I'd say be prepared for anything, including drains plumbed into vent lines...
  • Bobbo's avatar
    Bobbo
    Explorer III
    Every manufacturer is different, but I doubt if it's a slip fit with a gasket. Too great a chance of leaks/odor.
    Better plan on cutting the pipe(s).
    According to the plumbing diagram from Winnebago, MY rig has one pipe plumbed into the top of the grey tank, the vent pipe. The kitchen sink drain T's into that pipe, and the shower drain T's into the sink's drain pipe before it gets to the vent. (My bathroom sink is plumbed into the black tank.)
    Yours may have 1 (plumbed like mine), 2 (vent and sink(s)/shower), 3 (vent, sink(s), shower), or even 4 (vent, kitchen sink, bathroom sink, shower).
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 13, 2025
