BFL13
Aug 28, 2016Explorer II
Thanks for posting those results! Very interesting!
I do have an actual "industry" test report on a proto-type design converter they built where they give the test result for "max efficiency" defined by them as "charger output power (current x voltage) / input power (current x voltage) where they got 83% in that case
So looking at these numbers from above:
"DC volts 13.66, DC amps 39, DC watts 533
AC volts 119.4, AC amps 7.45, AC watts 636, AC volt-amps 896, pf 0.7
Crunching the numbers, efficiency in terms of watts is 83.8%, in terms of VA it's 59.5%. So if the "industry" statement were true, the efficiency is 59.5%."
The DC output watts at 533 checks, but I don't understand the AC figures. 119.4 x 7.45 = 889.53 so where does that 636 come from?
Going just by power out/power in, I get 533/890 = 59.9%
That is where I get the notion that " the industry" counts PF in with "efficiency"
How do we resolve these different interpretations of the actual measurements taken on that 9855?
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
