ktmrfs
Aug 29, 2016Explorer III
road-runner wrote:MrWizard wrote:Has there been a post from somebody who actually uses an eu1000i with a PD converter at an actual measured 55 amps? I've noticed only a lot of arm chair guessing. I can tell you that when I ran the 9160 with a low battery I had to switch the fridge to gas only to keep the eu2000i from tripping out. This was after moving the converter next to the battery with a big wire. With the factory #6 wiring it could never push more than about 30 amps under any conditions.
but those numbers don't match the users who say they can charge 55mps from a PD55 using a 1000w honda
I'm now using a PF corrected prosine 2.0 (I consider this temporary because it sounds like they all die young). My 800 VA generator maxed out at about 30 amps charging with the PD converter. With the prosine it will do 40 amps.
I'll agree with your assesment. I have a PD60 in my trailer. At sea level there is some reasonable margin at 50-60A output, but not much. Fridge on 120V would be very iffy. at high altitude there is very little margin.
And I have a friend with a honda 1000 and it will NOT run the PD 60 in boost mode with a low battery and even the 45A is hit and miss in boost mode. With a low battery he needs to start out in the non boost mode till to keep from kicking out.
