dougrainer
Jan 16, 2014Nomad
I will give you my experience and knowledge. The OEM's have found that ANY type inverter LESS than 600 watts will not work correctly in your set up. I have found that some LCD TV's need a hi watt surge to start them up. Once they are started, they consume that 33 watts or so. Going less than 600 watts will probably just cause problems. Spend the money for the 600 or higher. Doug
