time2roll
Jan 16, 2014Nomad
Typical RV plug is good for 8 amps or about 100 watts max.
May get low voltage shut down before you even get full wattage.
You need a 150w or less inverter to use the 12v connector.
May not be enough power especially all at once.
This is why I suggested the hard wire behind the circuit panel.
