wa8yxm
Jul 01, 2014Explorer III
I have continued thinking on this... On most every 30 amp plug I have worked on the ground pin, which is round or "U" shaped.. Is very easy to pull out of the plug body.
The HOT and NEUTRAL can also be pulled but not nearly as easy.
This is due to the shape of the pin,, It is not a design feature or flaw..
But the solution, as I posted above, is to put the cover on the plug (The back cover) as this holds ALL THREE pins in place.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
