time2roll
Jun 05, 2016Nomad
30 amp RV? If you rewire both to operate off the 30a panel you will really be maxed out. Also a 30a panel is limited to five branch circuits so something else may need to share such as electric water heat and microwave.
Otherwise you need to pull wire from the switch to the panel to get power to both. Or as said above to break out power from one of the units to a separate plug.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
