pianotuna
Jun 06, 2016Nomad III
Hi,
I fail to see why this "safe rv" is any better than simple male and female plugs. I have two auxiliary shore power cords.
Lantley wrote:pianotuna wrote:
So with this device can you have both the OEM and auxiliary shore power cords active at the same time?Lantley wrote:
Check out safe RV power. This transfer switch is designed to do exactly what you want. I just installed one on my fiver
Safe RV power transfer switch
Yes, essentially it switches the A/C circuit from standard circuit breaker feed to auxiliary 20 amp pedestal power feed
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
