Chris_Bryant
May 13, 2015Explorer II
Joe417 wrote:
I've also removed a loose fixture, carved out the foam insulation, and installed the appropriate sized wood framing around the opening to give me something to screw to. That takes more effort but is probably the best method as it will probably last longer.
This is how to fix it- the vent has a large opening, and you really need to remove it for any good fix, so why not fix it right, and for good.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
