BFL13
Jun 03, 2020Explorer II
How Can You Tell if an AGM is Really "Deep Cycle"?
We know about marine/RV batts being not so good at that compared with "real" deep- cycle batts like T-105 6v or T-1275 12v batts.
I am suspicious that AGM "deep cycle" batts might be more like marine/RV batts, especially when noting they have lead-calcium plates.
EG, this one says it has a charging rate for "cycling", but is it meant to be repeatedly deep- cycled doing 50-80s off-grid and then fully recharged when you get home to "recover" it?
http://www.wegosolar.com/products.php?product=Deka-8A27-Absorbed-Glass-Matt-92-AHr-Solar-Battery
OTOH, this one claims to be deep-cycle and the blurb says it is unlike the usual AGM standby batts. It also has charging rates for both "cycle use" and "standby use", so what's the difference--if any?
How much is just advertising like Walmart saying their marine/RV batts are 27"DC"?
http://www.wegosolar.com/products.php?product=SKR%252d125AGM-Stark-AGM-12V-Solar-Battery-Sealed-125A
Especially when that Stark batt is from the same factory (AFAIK) as this one but different labels on it?
http://www.bestconverter.com/UB121000-100-AH-Deep-Cycle-_p_293.html#.XthXKUBFxpw
I had an AGM 8D that said it was for "cycle use" and "standby use" with almost identical specs as the Stark one except more AH of course. It could not "take" my kind of usage. IMO it was more of a "standy by" battery.
This 8D also has both uses listed, but the blurb stresses its value for standby use. At least this one might be hinting at the truth?
http://www.wegosolar.com/products.php?product=Deka-8A8D-Absorbed-Glass-Matt-245-AHr-Solar-Battery
However some members here have "telecom" AGMs that work well for their usages. But we don't really know what that usage is like.
So if you are shopping for an RV use AGM and would normally get T-105s or T-1275s can you just go ahead and get the AGM versions of those batteries? Trojan says those AGMs are for the same use as the Wet versions, but should you think they are lead-calcium and not the same at all? (Trojan doesn't say if they are lead-calcium that I could find)
So what is the truth about AGM batts for RV use deep- cycling for real?
How can you tell from the specs what's what?
( Mex gave some good info in another thread related to this too, but not directly answering these questions.---one of his points was that a battery with a few thick plates weighs the same as one with lots of thin plates)
