wolfe10
Sep 26, 2018Explorer
fj12ryder wrote:
How can you tell short of checking the power outlet with a VOM?
Will you have to rent a separate site to charge your EV? That could get expensive.
Very easy with a voltmeter:
Each outer straight is a HOT.
So outer straight to outer straight with proper 50 amp= 240 VAC
Improper 50 amp= 0 VAC
While you are there, check either outer straight to center straight (neutral) and to center round (ground). Should be 120 VAC.
Takes less than one minute.
