fj12ryder
Sep 26, 2018Explorer III
wa8yxm wrote:Sorry, I should have been more specific, a fault I often find with others. :)fj12ryder wrote:
How can you tell short of checking the power outlet with a VOM? Will it show up using a EMS?
Will you have to rent a separate site to charge your EV? That could get expensive.
EMS is a multiple meaning Acronym
A progressive Dynamics EMS. I do not think so
An Intelletec EMS will show 30 amps on a cheater site.
Note that these are two ENTIRELY different devices which perform different jobs .
I used to have (Still do somewhere) a Neon tester that would do it.
but if I wished. . I could put together a simple indicator consisting of a Resistor (I'd have to work out the value) and a simple Neon Lamp (NE-2) you hook it to the two MAIN breakers or two branch breakers on different branches in the RV. if it's lights. Genuine 50 amp. if not cheater site.
Same test the Intelletec uses in fact.
But would I see any indication that the pedestal is suspect with the readout/indicator lights from my Progressive Industries EMS-PT50X Portable 50 Amp Electrical Management System? I had to replace my SurgeGuard that gave up the ghost a few days ago and bought this one. Any information would be appreciated.
