dougrainer
Sep 27, 2018Nomad
westernrvparkowner wrote:dougrainer wrote:My research indicates cheated 50 amp service occurs on a percentage exactly equal to the percentage of crooked RV repair people. However, I could be wrong, because these forums sure have a lot more complaints about incompetent repairs then they do about RV parks with cheated 50 amp service. Seems like you would be much more likely to find fraudulent RV service than you are likely to find fraudulent 50 amp services in a RV Park.
I have had numerous customers call me over the years with their OEM EMS systems, stating 30 amp service, when they are plugged into 50 amp service. That is because the CG has CHEATED 50 amp service and not correct phased 50 amp(100 amps total on 2- 50 amp breakers). ALWAYS, The CG says they are 50 amp service. The customer comes in and I plug into our 50 amp and show him the EMS shows 50 amp service. He then realized the CG either lied or did not understand 50 amp service. The flip side is, the customer calls me and I tell him how to check the CG 50 amp plug for 50 amp service and it is ALWAYS cheated 50 amp. For any CG to advertise 50 amp hook ups and CHARGE for 50 amp hook ups and NOT supply a total of 100 amp supply is fraud. Doug
PS, yes it is common, but unless you have a 50 amp built in EMS or check it yourself, most people would never have a clue. It is usually older CG's that would cost them tens of thousands of dollars to correctly upgrade to safe 50 amp service
MY research indicates that crooked RV park owners will protest too much and blame other people on forums, to deflect the question and problem:B Doug
LIKE POLITICIANS:E
