John___Angela
Oct 01, 2018Explorer
westernrvparkowner wrote:
I disagree wholeheartedly with the signage idea. It is impossible to sign every possibility of misuse of the park. There is another thread running where someone's kids spraypainted trees and picnic tables. Is a sign needed for that as well? If you want to use the park facilities for anything other than what they were intended for, ASK. (And be willing to accept the answer)
Yah I suppose at some point signage can be overdone. Common sense and manners should rule but, you know, there’s always one....
As an RV park owner you are certainly better equipped to answer this question. Have you had to deal with this yet? If so how did it go? Good to have a campground owner on here discussing it. Any plans for a couple level two stations? This could make it a bit more of a cash flow item...eventually. :). Not a lot out there yet but a couple thousand more every day.
