sum1
Dec 09, 2013Explorer
westend wrote:Agree. I use silicone only to seal mounted fixtures that may need to be removed, as a gasket, if you will. I prefer quality marine polyurethanes for permanent aluminum and fiberglass installations and joint sealing. I've had good results with Dicor on the rubber roof and Eternabond or similar "tapes" for rips.
Silicone is an excellent sealant between two surfaces held in compression. It doesn't tolerate sunlight, weather, or movement very well.
